j-d
Oct 01, 2013Explorer II
Incorrectly installed gasket isn't unusual. Just dug the engine out of an Ez-Go utility cart to replace one. Pulled away at one point where it should have been in contact with the two surfaces.
Bite the bullet and fix it right. Ah, but, can you source the correct gasket? You may have to make it.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
