Jim_S_'s avatar
Jim_S_
circuit breaker location
I have a 2005 Sunnybrook model 2706. It has circuit breakers located in 3 places, above the sofa, in the breaker box and a third location that i cannot find. I know there is a third location because i had to take it to a dealer once before after the campground took a lightning strike. The dealer fixed it but did not tell me where it was located. Anyone have any thoughts???
1 Reply
  • wa8yxm's avatar
    wa8yxm
    Do you have an inverter? If so it may have breakers mounted on it,, often on the side you can not see (of course) use an inspection mirror.
    Also there may be some 12 volt breakers.. My Gasser has an Inetlletec Battery Control Center... Diagerams downloaded from the manufacturer of said device show a pair of POST type (PUSH HARD TO RESET) Breakers,, I do not have them but the diagram shows them (I have a self-resetting breaker nearby.)
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
