westend
Jan 27, 2016Explorer
Remove the pilot tube and orifice. Blow compressed air through the orifice in the opposite direction from normal flow.
You can clean the tip of the outside of the orifice with an automotive spray cleaner and a toothbrush if it makes you feel better. It usually does nothing to fix a clogged orifice and that sounds like what you have.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
