billw928
Aug 10, 2014Explorer
I had the same problem. If you experienced low batteries and had to charge them or if you changed your batteries you may have the code 46. Before you take it In try the following to attempt to clear the code. Hold the start/stop button for 30 seconds and then run the genset for 15 minutes and then see if code has cleared. This worked for me.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
