tarnold's avatar
tarnold
Cold tire pressure vs hot
Trying to set a tpms system. How much should a 225-75-16 tire pressure rise from 60psi cold to ?hot?, assuming outside temp of 70*. On the tpms you set for cold pressure. It will alarm at 15% . I wanted to alarm at a recognized 55psi. So if I set to say 63psi then it falls 15%, that would be around 55psi, or close enough. BUT coming from the tire store today it alarmed as high pressure and showed 73psi as the tire warmed up. Best I can explain it.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
