theoldwizard1
Mar 14, 2022Explorer II
Lwiddis wrote:
Matt's right. Get it fixed right. It will never fix itself and makes your vehicle undependable.
AGREE !!
Start by buying an amp clamp meter. Under $75. Make sure it does DC amps. Simply clamp it on either the positive or negative battery cable in the engine compartment. You might get a reading for a couple of minutes after turn off the engine before it goes to very near zero.
It you me getting a reading, you will need to do more investigation. This can be a bit daunting for a novice but there are a lot of videos on YouTube.
