hedge's avatar
hedge
Connect fuse directly to battery terminal?
Can I connect a Mega style fuse directly to the battery terminal with the other end connected to the cable with a bolt? If it blows does the fuse stay in one piece?
I installed new batteries and they are taller and I don't have room for my Blue sea terminal fuse mount anymore.
Is this type of catastrophic fuse even necessary? The wire goes directly to a switch and from there to circuit breakers before any loads so it seems to me it should be pretty well protected. It certainly didn't have a fuse in their from the manufacturer.
