cavie
Mar 27, 2020Explorer
Before you do anything, the storage compartment must be HIGHLY vented at ALL TIMES and HIGHLY sealed off from the interior of the trailer. Installed in a battery box that is vented to the outside is one way. Battery vented gases can kill you.
The wires from the inverter to the battery must be sized to the wattage of the inverter installed and the distance to the battery. It's called voltage drop. They will be large. You cannot run the complete trailer off the inverter. You will need to install a inverter sub panel and wire just a few things to it. Batteries do not provide enough power to run A/C and WH's. Sounds like it's time for an electrician.
The 12 volt system works with the converter turned off because it keeps the battery charged. If it is off all will work until the battery goes dead.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
