CA Traveler- Is that a piece of copper water pipe? This may work for me, as this is a temporary set-up until the weather warms up, and I can complete my new wiring. I'm leaving for Texas next week on my first trip with the MH.
The plan is to use the living room cabinet for the new converter, a 300W inverter, and the cheapo Chinese meter. This cabinet is directly above the battery bay, which has room to add an enclosure box to house
the bus bars, shunt, a few fuses, and a main disconnect. At that point, only 1 set of cables will run to the batteries.
smkettner- I have 2 lugs on the positive terminal now, I'm thinking 1 is the engine alternator, and the other to the DC fuse panel. The top of the stud barely gets through the nut.
Steve
