RGar974417's avatar
RGar974417
Converter/charger
We have a 26ft Keystone Cougar TT. Prior to that we had 2 Sunlines.I have a had a dual battery set up for years. With the Sunlines,I could go 4 days without recharging the batteries. With the Keystone,I have to charge them every day. I have 2 group 24 deep cycles. That is what I have always used.Since I have had the same set up for years, and got longer use with the Sunline, I assume the charger in the Keystone isn't as good as the ones on the Sunline. So my questions are, where is the unit located? I assume behind the fuse panel and ,what is a good charger to replace it with Thanks.
  • An upgraded converter-charger is not a bad investment.
    A better investment is a battery hydrometer and a multi-meter with a current current clamp. I have a this Uni-T B4Q094 UT210E meter but there are many other to choose from under $100. With this meter you can check the charging voltage, the resting voltage and the amount of current being drawn when you THINK everything is turned off !
    It is unusual to to find "true" deep cycle 12V batteries. The most common true deep cycle batteries are 6V golf cart batteries.
  • RGar974417 wrote:
    ...Since I have had the same set up for years, and got longer use with the Sunline, I assume the charger in the Keystone isn't as good as the ones on the Sunline....
    I doubt the converter/charger has anything to do with it. I would assume that the newer RV is using more power than the previous one. Additional sensors or systems?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
