Corliss's avatar
Corliss
Converter charging at 16.3 volts
I installed a new light fixture with led bulb in my rv, after the first hour of use it exploded. Before I returned the burnt light fixture and blown bulb back to Camping World where purchased I thought I should check the polarity and voltage to the fixture. I found polarity to be correct but the voltage to be 16.3 volts. I unplugged the rv from 110 supply to find the voltage went to battery power. I'm now thinking the high converter voltage could have caused the led bulb to blow? My converter is made by System Monitors Inc who is out of business. I would like a wiring schematic to repair the current charger or advise on a replacement converter. Any advise would be greatly appreciated.
