gsf35099
Jan 18, 2015Explorer
Converter issues
Anyone ever seen a converter cause an AC issue like shorting out the GFCI?
My 30 amp converter has no output between the positive & neutral & 20 volts between positive & ground. Thing my converter is fried.
I was running my TT off a generator and only running the heater (12v & propane). Then the refrigerator started to turn itself on. I would turn the frig off & it would turn itself back on. Then we noticed a burning smell & poor the GFCI outlet in the bathroom fried. Pulled it out and removed it after killing the power. Applied power again with nothing running & everything was fine. Turned on only the heater again and the GFCI outlet in the kitchen started to fry. That is when I removed the converter and started measuring.
