gillis's avatar
gillis
Converter problem
Hello , I am having a problem with a WF- 8835 converter . It will not charge my battery and it none of the 12v systems work . I have checked all fuses , they are good . I removed the wires from the converter and checked the output which was 13 volts not 13.6 like the manual says it should be . So should the 12 circuits work even if the battery is out of the unit ? Also is the 13 volts good enough to charge my battery? Currently nothing on the 12v side is working .
Please help Thank you
Bill
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
