Muddydogs's avatar
Muddydogs
Converter running question
When testing my solar set up I went in the trailer to see how the volts and amps looked, right away I could hear the fan on the converter running full out. Solar was topped out at 13.8 volts into the battery's, only thing running on the trailer is the fridge on propane, CO2 detector and what ever else runs to keep it alive. So why is the converter fan running? I assumed it just got hot when more power was running through it or when working to process shore power. Inside trailer temp is 95 degrees.
