BFL said:
“I still have not got an answer for what you do if your rig has an inverter/charger. Last heard, an inverter/ charger will not operate at 12v unless it it is connected to a battery to run its own systems. Not sure if it still would do 120v pass through.”
My pass-thru inverter-charger always stays connected to the batteries, whether on shore power or not…As power passes thru, it normally remains in just the ‘standby mode’ (or, OFF) - it’s built-in ATS switch prevents conflicts with incoming shore power…
3 tons
