Vic_Bc's avatar
Vic_Bc
Converting to Solar/AGM
Hey folks,
I just recently installed 2x 95W Solar Panels, 1000W pure sine wave interver interver fuse, and regulator
I'm looking to upgrade my house batteries to a bank of two lifeline 6volt (400aH) wired in series. I'm a bit concerned as I currently only have one flooded deepcycle for a house battery which is charged by the alternator and when plugged into shore power.
Do I need to change the charger? I'm not that tech savvy when it comes to electricity, this is a whole new venture for me. My friend is an electrician and he mentioned I could run an extension cord from my male plug (that is used to connect to shore power) to my inverter so all the outlets inside work (they currently only work when plugged into shore power). I'm just a little concerned that double charging the battery might get messy.
Also, I'm changing to AGM which I now need to keep an eye out for overcharging, correct? The solar regulator will take care of that. I was told there should already be a regulator installed for when I'm plugged into shore power? (I drive a 1990/1991 Dodge Islander. It also leaves the issue of the alternator, do I need to change everything as the house battery gets charged while I'm driving as well.
I'm just trying to make this switch to AGM smooth. I hope my questions are clear.
Thanks for your time
-Dustin
