DFord wrote:
This search on Amazon shows a lot of parts for the 310 including the ball/gate flush valve: https://www.amazon.com/dometic-310-toilet-parts/s?k=dometic+310+toilet+parts
Here's a link to the 310/320 PDF manual: https://olivertraveltrailers.com/wp-content/uploads/oliver-university/Component_Manuals/Toilets/Dometic_310_series_manual.pdf
I see several YouTube videos for 310: https://www.youtube.com/results?search_query=dometic+310+toilet+flush+ball+replacement+
Exactly what part is not replaceable?
https://www.amazon.com/Dometic-385318162-Ball-Shaft-Cartridge/dp/B003WOIT04/
![](https://images-na.ssl-images-amazon.com/images/I/51qP4sAUJ-L._AC_SL1200_.jpg)
The Amazon Parts show a ball valve kit.....BUT it is NOT for the 300 Series (300/310/320) Bowl/Base are GLUED together. Can NOT be separated so access to ball valve does NOT exist PERIOD
Other parts show (water valves, bowl seals etc are for the 300 Series
The ball valve assembly shown is for numerous OTHER models but not 310
The Owners Manual LINK even shows that there is NO part designation for the ball valve cause you can NOT replace it
YouTubes........none show replacement of a 310 ball valve. They show bowl seal replacement, water vlave replacement etc NOT Ball valve
The dang ball valve is NOT replaceable.... can not order one cause Dometic does NOT have a replacement part number for one.
It is not that difficult to comprehend......or is it???
Dometic Sealand 385318162 Toilet Flush Ball Shaft Cartridge Kit
Fits Models
106 111 131 168
206 208 248
306 308 348
506 506+ 50706 508 508+ 509 510 510+ 511 511+ 547 547+ 548 548+ 558 558+
606
706 712
806 808 847 848
906 908 910 911 911-28 911-36 911-M28 980
1006 1008 1047 1048 1049 1088 1106 1606
2010 2011 2011-M28
NO 300, 310 or 320 models listed
