- Chum_leeExplorerFlooded lead acid batteries can and will explode. How do I know? Because I've done it. It takes some work (and a momentary lack of intelligence) to do it. Here's what I did.
On my first car, with small block Chevy V8 and and aging battery, I decided to perform a compression test. Since the battery was weak, I put the shop 50 amp boost charger on it as I performed the test so that the battery would not go dead. The battery began to gas. I cranked the starter several times as I checked the compression in the various cylinders. So, the battery was discharging from the compression testing, AND, at the same time, being charged (at 50 amp rate) from the charger. I accidentally clipped the charger cables with my elbow, (spark occurs) and BOOM! The caps blew off the battery, the lid on the battery split in several places, and battery acid went flying everywhere, including in my eyes and on my clothes. So, yes, IT CAN BE DONE!
You really have to work at it though. Even with trickle charging, IF THERE IS NO ADEQUATE VENTILATION AND SUFFICIENT TIME, it is possible to concentrate hydrogen/oxygen sufficiently so that if a spark presents itself, . . . . . BOOM! In a confined space, expect the worst. Unlike gasoline, hydrogen is explosive at very low concentrations. (lean mixtures)
Chum lee - MEXICOWANDERERExplorerFailed Harbor Fright maintainers short out at 16.3 volts. I have seen enough of them.
The company has on retainer a product liability specialist based in Manhatten Beach, CA. Good luck with that.
Delco Remy started this Fuster**** in 1980 with the 15SI model with the 1117405 voltage regulator set at 15.0 volts, and a calcium/calcium battery. Low IQ meant GM went with copper-plated battery cables. Never under-estimate the idiocy of a bean counter (Robert ***STRANGE*** McNamara.)
Beware of untested under reviewed "new electrical miracles". - joebedfordNomad IIII was happy when I put it in there/ Hopefully still happy when taking it out.
- I had a Harbor Freight cheap Battery Tender years ago connected to my 1975 Corvette. I had a good Interstate sealed side post battery. Corvettes have the battery inside a fiberglass box behind the drivers seat with a latched sealed lid. I don't drive the Corvette that much. about 15 years ago, I decided to start it up after sitting for about 3 months. Battery tender still connected. The minute I turn the Ignition key to start, BAM, the lid of the battery blew off and luckily the battery compartment lid kept the remnants IN the battery box. The Battery tender had boiled the battery dry and the Instant draw from the starter combined with the Battery minder connected provided the spark to blow the gas. Lesson learned. I purchased a more expensive Battery Minder and now I monitor the Water Level in the battery before I run the car now. NEVER had a problem in the past 15 years using a GOOD Battery Minder. Doug
joebedford wrote:
Yes, there are 6 x 6V batteries.
No, I didn't leave a tender on them. I charged them up fully then drove the cart into the hauler. Didn't disconnect other than cart switch off.
There are no windows open but I did leave the main air conditioner on at 85F.
RV AC units are sealed systems. They only recirc the Inside air. NO outside air at all. Your AC unit when on would just help distribute any possible corrosive gassing thru out the box. Doug- MEXICOWANDERERExplorerStanding 10' from the muzzle.
Anything from a .410 gauge to a 16 gauge shotgun discharge. Armando had a Mexican grade hangover (a near-death experience). He put two golf car batteries in series by dead shorting them. A 410-grade pop ensued. Hosed him down with cold water. His pants later turned into a Calvin Klein masterpiece. beware
Sorry, kiddo a no-pay day. Sent him home with Tylenol.
He never again griped about having to wear wraparound Lexan goggles.
beware of saint monday after the world cup. - Sam_SpadeExplorer
dougrainer wrote:
A proper Battery Maintainer will not outgas.
I THINK THAT IS WHAT I SAID.
There is a reason that good Battery Minders cost a lot less than the Harbor Freight cheap ones. Doug
And for the second sentence......I think you meant MORE not less ??
Then....there is a difference between outgassing due to electrolysis, which is what produces H and O.....and WAY overcharging and getting the battery HOT so that the acid solution gives off FUMES.
The corrosion is caused by acid fumes, not the gasses produced. - joebedfordNomad IIIYes, there are 6 x 6V batteries.
There are no windows open but I did leave the main air conditioner on at 85F. - wa8yxmExplorer III
SidecarFlip wrote:
Not really so long as there is some air movement. I have to say that I've never seen a battery explode, heard of it happening but I've never had it happen personally
First too I'd roll out the Golf Car. (Sing to the obvious roll out tune) before I started to charge. Just to be safe.
Should not be that hard to do. If you can't roll it out open the tailgate and put in a fan.
Battery Explosion I have heard of it happening when two batteries were hooked up "Back to back" instead of side by side I mean
Dead 24 volt short blew one or both up But normally a battery "Explosion" is more of a "Pfft" than a "BANG" that is the case cracks and acid is sprayed all over the battery compartment..
IF this happens.. Hose it down FAST cause as others have said not good for the metal in your garage.. or anything else for that matter. But if it happens. I would EXPECT it to happen fairly soon. (Like 1st hour) and unless the batteires are totaly gone you should be able to move it out
NOTE: at least one make of Golf Car if the batteries are truly flat the charger won't.. Well there is a way to jumper two connections and it will but basically it won't.. And no I can not tell you which leads (Without the diagram in front of me) but this type has a 3 prong charger to Golf Car plug as I recall. The charge controller is split between the charger and the car... If the batteries are totaly dead (like 2 years no charge) they can not power the car half of the charger control circuit. - DFordExplorerHere's a little background information for those that will accept proper practices for ventilating batteries when charging:
https://na.bhs1.com/battery-room-ventilation-code-requirements/
For the rest of you, good luck! You'll need it. It's the only thing keeping you in one piece so far. I've experienced gas explosions and I can tell you you'll never know what hit you because you get no warnings.
The golf carts I've seen have 6 - 6 volt batteries in series (36 volts). So we're not talking here about charging just one battery. We're talking about a group of batteries.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
