wa8yxm
Apr 15, 2019Explorer III
Bobbo wrote:
Ignore wire color, there are too many "standards," and none of them are standard. Trace BOTH wires from the battery. ONE of them should go to the frame. THAT is the negative cable.
I have never, ever, seen a negative cable with a fuse or circuit breaker on it. I would bet money that the cable withOUT the fuse or circuit breaker is your negative cable.
Best advice I've seen in this thread. I do not trust colors in RV's cause they are wired by ELECTRICIANS not AUTOMOTIVE technicians or Electronic Technicians (I'm cross trained so I know both Traditions but THERE IS NO STANDARD!!!)
