MEXICOWANDERER
Aug 26, 2014Explorer
DC to DC converter For Equalizing
This gizmo needs enough amps and volts (watts) incoming from a charge source to work. It cannot manufacture electricity.
But
It does have the capability of producing a CONSTANT 16 volts by virtue of precision adjustment
AND
Limited meaning REGULATED amperage output 1 to 10 amps (max) ADJUSTABLE! Yes, regulated current limiting!
Power in meaning supply voltage must not exceed 16. Do not get confused. That figure is for INcoming voltage the supply voltage
With solar panels REGULATED or a POWER SUPPLY power source such as the MeanWell or MegaWatt this little puppy means REGULATED equalizing voltage AND AMPERAGE
A dream come true.
Couple this with an Intermatic spring wound timer and Santa has come early this year...
http://www.ebay.com/itm/600W-CC-CV-12-60-to-12-80V-DC-Volt-Converter-LED-Driver-Regulated-Voltage-Supply-/351146021015?pt=LH_DefaultDomain_0&hash=item51c1ef1097
But
AND
A dream come true.
