โDec-30-2014 06:48 AM
โJan-27-2015 06:39 PM
Harvey51 wrote:
Yes, I just ordered four more for friends. The plastic box can be opened but is pretty well sealed . I wouldn't hesitate to leave it underside, but would use tape or something to make sure the seam is sealed.
I'm not leaving it on indefinitely since I found that, after two days on an engine battery, the battery voltage was 14 V and stayed above 13 for two full days.
โJan-27-2015 03:24 PM
โJan-27-2015 10:13 AM
Harvey51 wrote:
I totally underestimated the things! I checked the voltage with no battery hooked up! There is no voltage when not hooked up to a battery - it jumps to 14.5 V as soon as it senses the battery. The pilot light is red under no load, turns amber, then red as the battery becomes fully charged. The voltage drops to 12.9. These $7 Chinese chargers are smart charging! All four of them work just fine!
I will edit out the bad news in my previous post.
Thank you jrnymn7. I also had an experience like that with a one way battery monitor. Thank goodness I had not got around to complaining to the seller. I had given two of the Minders to a farmer friend of mine and his were still working. He reminded me about the color change and it somehow triggered the thought that I should try with a battery hooked up.
โJan-17-2015 03:08 PM
โJan-17-2015 02:13 PM
Harvey51 wrote:Harvey51 wrote:
I just got 4 of these $5 ones. They all work, putting half an amp into a car battery or garden tractor battery. Better than I expected.
http://www.ebay.ca/itm/Car-Truck-Motorcycle-12V-Smart-Compact-Battery-Charger-Tender-Maintainer-FNRG-/390939425642?pt=Motors_Automotive_Tools&hash=item5b05ce3b6a
I withdraw the recommendation!!! Two of the four have already failed after one use. I took them apart and found a complex electronic circuit beginning with full wave rectification of the 120 V input, which part works. Looks like an improvised switching power supply. I reheated all the solder joints with no effect.
โJan-17-2015 08:43 AM
โJan-04-2015 03:19 PM
โDec-31-2014 07:04 AM
โDec-31-2014 05:15 AM
โDec-30-2014 10:11 PM
โDec-30-2014 08:14 PM
โDec-30-2014 07:08 PM
โDec-30-2014 05:23 PM
โDec-30-2014 04:50 PM
Flyfasteddie wrote:
I have both. I've had a 12117 for a few years and I've wanted to get another one so I bought a 1500 from the manufacturer during a black Friday sale.
The primary difference is that the 1500 is temperature compensated and the 12117 is not. I prefer using the 1500 this time of year because charging at 40F with the 12117 doesn't bring the voltage up high enough to fully charge.
Another interesting tidbit is that while the 1500 has a slightly higher amperage rating, the box that plugs in the wall is half the size and half the weight of the 12117.
