DEAD DEAL Inexpensive BatteryMINDer $14.99
beemerphile1
Ran across this deal at Northern Tool and thought I would share. I have two Deltran Battery Tender but have lusted after the BatteryMINDer with desulfation pulse mode.
I use these to maintain the tractor and motorcycle batteries.
I guess I am a battery charger junky because I also have a VEC1093DBD and have upgraded both converters to 'smart' converters.
Apparently the model #12117 BatteryMINDer has been discontinued. It is being replaced by the model #1500 which adds temperature compensation and slightly higher output. Both models have the desulfation pulse feature.
Your choice, the model #1500 at $50 or model #12117 for $14.99.
Northern Tool BatteryMINDer #12117 for $19.99
Enter Keycode 197926 for an additional $5 off.
Edit;
Changed title, apparently the cost has increased to $29.99.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
19 REPLIES 19
Flyfasteddie
I have both. I've had a 12117 for a few years and I've wanted to get another one so I bought a 1500 from the manufacturer during a black Friday sale.
The primary difference is that the 1500 is temperature compensated and the 12117 is not. I prefer using the 1500 this time of year because charging at 40F with the 12117 doesn't bring the voltage up high enough to fully charge.
Another interesting tidbit is that while the 1500 has a slightly higher amperage rating, the box that plugs in the wall is half the size and half the weight of the 12117.
tenbear
I use that model of Battery Minder and love it. Never have had a problem with it.
2010 Subaru Impreza Sedan
Empty_Nest__Soo
That's a great deal!
I have 3, and I paid near $50 for each of them at different times.
Wayne
Wayne & Michelle
1997 Safari Sahara 3540
bob213
Thanks beemerphile1. Just what I was looking for!
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
otrfun
Was just gettin' ready to order a replacement BatteryTender Plus for $50.
Think I'll give the #12117 BatteryMinder a try instead. $21.48 shipped to my door ain't bad--not to mention the desulfation mode.
Thanks, beemerphile1!
