kampinguru
Sep 21, 2015Explorer
Dicor sealant question
I purchased 4 gallons of the Dicor roof sealer and two quarts of the activator prewash. When I put the first coat of sealant on, it said 125 sqaure feet coverage per gallon. I have a 8 X 32 foot roof which is 256 Square feet so I would suspect that two gallons per coat would be tight. I finished the 1st coat with a little over a gallon. I thought I was putting it on thick but apparently not. I put the second coat on when the first was dry to the touch as per instructions. I put it on real thick and only used a gallon and a half. Is it possible to put a third coat on at a later date as I still have a gallon and a half left.
