fred42
Jan 23, 2015Explorer
Did you ground your PD 9200 series converter?
I recently installed a new PD9260C deck mount converter in my fifth wheel. It did not come with anything resembling installation instructions, but it did have this schematic:
The converter AC power cord is 3-prong, so it has a ground and a 15a breaker, but this seems to want the converter body to be grounded to the chassis via the grounding lug. I have seen several installs on YouTube and only one used a separate chassis ground with these 9200s. That was because the unit replaced had a ground. The standalone, plug-in, deck-mount converter I replaced (WFCO WF-9855) did not have a separate chassis ground.
What would you think they did with the 120v AC ground wire when it entered the converter. Don't you think they would have connected it to the converter chassis? If so, that wire already goes to the distribution center ground bus which appears to have a larger bare wire going somewhere, I presume the coach chassis.
thanks for any ideas,
Fred
Fred
