Gdetrailer
Feb 27, 2018Explorer III
tommymsw wrote:
AH HA!!! So....
I DO see some DC wires running a few feet under the light switch (going to the LP sensor). If I wire into THAT ground wire, should it work? Or do I need the EXACT ground wire that runs to the lights?
And I have 2 wires for (ground) on the switch. Should I put them BOTH to the ground? Or only one? and what one? IN or OUT? :)
The wrinkle to that plan maybe as DrewE pointed out..
Some of those dimmers actually pass the pos lead at full voltage and reduce the ground lead (IE "lift" the ground potential).
That type of dimmer using only one ground lead will not work and you would need to have 4 leads, two from the battery pos and neg plus two going to the light pos and neg.
Won't know which one you have until you try it.
