A Titan BrakeRite actuator will be installed next Thursday replacing the Dexter unit. The folks at Titan confirmed that their initial voltage for turn on is less than one volt—much less than the stated 3 volts for Dexter. The trailer dealer that I’m switching to called his contact at Dexter technical who confirmed that the higher turn on voltage is probably the root cause of my problems. I also noticed that the wire gauge requirement for the control line for the Titan is smaller than the Dexter. That tells me that the amperage draw by the Titan from the truck controller is lower than the Dexter—that’s good. I’ll also be using the Ford/Chevy adapter since Titan recommends it and the success stories seem to use it. Big thanks to Planning for posting the price at Eastern Marine—ground delivery in 3 days for $20. By the way the price match at ETrailer is more of a stall technique than anything else. I’ll post results after installation.
