pianotuna
Apr 06, 2016Nomad III
If you have a modern 3 stage converter by all means do keep it plugged in.
However 13.5 volts is a bit on the high side--so I'd consider doing 24 hours on and 24 hours off.
A better solution may be to monitor the battery voltage and turn it on if it gets below 12.6.
