RLS7201
Sep 10, 2019Explorer II
If the windows are just wet inside, they can be disassembled, dried out, cleaned & reassembled with new spacer material. I've done it. I elected to assemble a square with 2x4s clamped to my bench for reassemble. Make sure and purchase the correct thickness spacer. You want to make sure the 2 glass panes are perfectly matched. You could use your dining table if allowed by the lady of the house. How else may I get you in trouble? If the are foggy (mineral etched) new glass is called for.
R
R
