bob213
Jul 29, 2019Explorer
The depleted battery when you got home may have pulled too much juice when you hooked up to a good 120v source. Check the resettable fuse near the battery and charge the battery with a stand alone charger. See what that does. Regardless, if you replace the battery, check that fuse usually mounted on the frame near the battery.
