pchuckie's avatar
pchuckie
Documentation for this fuse panel/controller
I recently purchased a 2016 Bounder. I like to have documentation for all the systems in my RV's. I'm not talking about the user manuals that ship with the unit. This panel is not only the fuse panel but is like a central control unit for all the lights, slides, door switch. The light switch panels though out the unit are I think connected to this panel via telephone wire. I've searched for any information on the panel and got Nada.
  • When you open the door, the steps deploy, lights on the steps illuminate, and the forward lights in the coach illuminate. I'd likely like to eliminate the forward lights coming on. That would surely wake everyone up front if you opened the door. Im pretty sure it's this panel because when you open the door the door label changes from low to high input. It may also be that it changes from high to low, I don't recall the direction.
  • I couldn't find any website at all. Nor did google images return any pictures that match the panel with search criteria I used.
    I was using a space between the two words, now I got a sniff.
  • The manufacturer of Bounder owns the patent to the IllumaPlex. I dug around on their website for a while, found photos of many similar panels in parts department, no exact match yet. Their website says they are a phone call away. Try calling them. 1.800.509.3417.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
