ziffell
Oct 25, 2016Explorer
Dodge Mobile traveler
I have a 77 Mobile Traveler. If I put a volt meter on the coach battery and start the engine it will show well over 13 volts DC. If I plug the coach into 110 volt AC it doesn't show any battery charge voltage. If I disconect the battery The 110 volt circuts in the coach work but the 12 DC circuts don't. As it is the battery will be drained while pluged in and won't be recharged by the converter. It is a Power Converter charger Model PCM 15 NK. A manual would help. Thanks Arnie  jimdonothing@yahoo.com
