path1
Jul 13, 2016Explorer
Doing stupid things to my elec system...question
I'm going bad to worse. Last week I posted that I forgot to disconnect my house battery on class c then we took off snowbirding for 7 months in our trailer. Came back and after charging only got 0.97 volt. Batteries are shot. Yesterday I took out the batteries, to go get new. First cable I undid had a red collar on the cable. Thinking to myself great, that's the pos side its marker red. Then after pulling all the way out, discover both cables have a red collar on them. I think red collars are what somebody used to make cables.
So I can't tell difference of pos and neg (they both have red collar)
So before I hook up new batteries and screw something else up...
Is this test right to determine pos and neg?
Neg side should be grounded to frame? So just follow cable back and look. Then to confirm, start motor (so alt puts out some juice), put one volt meter probe on cable that is not grounded (which should be pos) and the other probe, ground out to frame.
This would complete a connection and will show up on volt meter.
Do I have this right or going to mess something up?
Elec is my biggest short fall on RV's.
Thanks
Thanks
