Dometic 9100 LED Strip Replacement
boss302
Has anyone replaced the LED Strip in the roller tube using the shortcut method of cutting a slit in the end cap? I know this works fine for fabric replacement. I then plan on using the existing wires avoiding dealing with the torsion spring.
0 REPLIES 0
