2002Sprinter
Apr 21, 2014Explorer
Dometic AC doing Weird things
It was suggested I post here for suggestions on this. I have narrowed the symptoms down a little more since noticing this issue. It has to do with how cold I set the Thermostat. Anything colder than 66 or so, it will trip out, shutting down completely requiring a recycle of the thermostat and or the breaker. The manual states that if the evap coil is freezing, and the thermistor (freeze sensor) located on the evaporator coil signals too cold to the board, 32 degrees I assume, the compressor will shut off, and the fan will go to high to defrost the coil. Anything above that 66, it is fine. Mine doesn't do that if that's what is happening. I have noticed the true temp is off by 5-8 degrees, the actual temp being lower than the thermostat says. Instead of cycling out, the compressor shutting down and then the fan, it just makes a sharp snap like a relay opening, and completely shuts down. Strange. I strongly think a new board may be in the future...:?
My original post to start with;
Hey all, new here but we've been a fulltimer for over 4 years. I discovered this thread through Google and my current Dometic Rooftop is setup with this type of setup, the newer digital stat and control box and board on a 15K straight cool Brisk Air, pretty new I believe. We purchased the trailer used about six months ago.
I wonder if I'm developing a board problem. At times I run the fan on low continuous at night as the compressor quicks in and out as needed, or even with the propane heat running. Several days ago, twice during the night, the fan went off. After getting the "I'm hot" nudge, I cycled the stat all the way through off and back to fan low constant cool mode and it fired right up. Again later that night, same thing.
Last night, (the other night) I couldn't get anything to start, fan or cool. So at 11pm I'm pulling the control box from the ac.. I see no problem and resort to turning off AC breaker, waiting and flipping back on. Unit starts right up. So recently, I'm running the propane heat, haha surprise lol, but before the propane heat kicks in, I hear the relays in the box, I still have it open, click about a 8-12 times as the furnace kicks on. The furnace lights and runs fine, cycles fine, but I hear the relays continue to click for about another 6 times, even after the furnace is cycled in.
Does this sound like it's developing an issue? Thanks.
Correction, its the 595 series of rooftop. Thanks for any suggestions.
Eta to show the newer controls there are there now, so it has been upgraded since the trailer was manufactured.
Dometic 3313189.000 Single Zone LCD Thermostat & Control Kit
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370843604297&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
![](http://i.ebayimg.com/00/s/MTI2OVgxNjAw/z/V4YAAMXQhpdRzGgN/$%28KGrHqZ,!lgFGjrhEH34BRzGgM28pQ~~60_57.JPG)
