โSep-20-2023 12:54 PM
โSep-24-2023 01:13 PM
โSep-23-2023 02:26 PM
โSep-23-2023 02:11 PM
H2oclass1 wrote:I assume it is the control box. Have the control boxes been switched?
My problem is in the living room. The one in the bedroom works fine. I swapped the two stat and the problem is still in the living room. Therefore I'm certain the thermostat is not the problem.
โSep-23-2023 01:35 PM
โSep-23-2023 01:33 PM
โSep-23-2023 10:03 AM
โSep-23-2023 04:21 AM
โSep-22-2023 09:17 PM
H2oclass1 wrote:Do both read the same temperature in each position when swapped?
Doug
I have seen the coils ice over.
I swapped the stats and the problem did not follow.
I only have the problem on 1 unit the other 1 is working fine.
Kenny
โSep-22-2023 05:20 PM
โSep-22-2023 03:18 PM
โSep-22-2023 03:13 PM
H2oclass1 wrote:
The EasyTouch RV 351 thermostat does read the freeze sensor. They call it Inside Coil Sensor. In there manual it says "Temperature of inside coil has dropped below 30ยฐF (-1ยฐC). The compressor will turn off and the fan will run until the inside coil sensor temperature reaches 54ยฐF (12ยฐC)."
โSep-22-2023 01:57 PM
โSep-22-2023 09:16 AM
