NRALIFR
Mar 07, 2019Explorer
Cleaning the burner and chimney is annual maintenance on an RV fridge. There is also a heat diffuser inside the chimney that should be checked. They tend to get the end burnt off of them over time. I would bet your LP pressure is low, though. You need a manometer to check it, either liquid or digital. If the LP pressure isn’t maintaining 11” of water column with the fridge running, you probably need a new LP regulator. As old as yours likely is, I wouldn’t even try to adjust it.
