ktmrfs
Oct 20, 2013Explorer II
Old-Biscuit wrote:p598738 wrote:
The RV is not level. Should it be to be using shore power ???
Level doesn't matter concerning shore power, battery power etc.
BUT IT MATTERS when operating fridge.
Absorption fridges use gravity/heat to cause cooling medium to properly flow.
Off level operation will cause improper flow.....insufficient cooling whether on electric or propane.
This can cause crystallization which will cause blockage and KILL the cooling unit.......Damage is accumulative!
x2. if it's not level enough for you to sit, walk, sleep in without noticing the "off level" the it isn't level enough.
