Oct-04-2023 09:00 PM
Feb-11-2024 07:43 AM
2023 wolf pup freezer is overworking fridge is not. I've tried resetting the snowflakes control temp. I've left the freezer open and turned off the fuse so it'll reset. I've tried completely unplugging the entire RV. NOTHING is working. Please help.
Jan-04-2024 06:02 PM
So i have been doing some digging.. I found a part list online at youngfartsrvparts . com/pages/dometic-dmc4101lss-product-id-936100408-parts-list its reference 289 for the part number. I called a local dealer in Yuma,, Rv World and they were able to order it for me with it takeing about a week to get..
I have also been chasing down lead on teh fan motor as well..
when i put this number in google some stuff on amazon come up .. seems this is a popular evap/ freezer fan motor for other units but not this exact one.. the plugs are different , this is a small 3 pin adn the shaft is 2" long from the hub.. I found a couple that have close to same 2000 RPM but the shaft if shorter.. so going to see what i can do to retrofit a cheaper way to fix these things.
Dometic has the parts fro this thing locked down TIGHT.. all i need is a fan motor but i gotta get all the other stuff.. stuff you have to remove to get ot fan motor.. go fricken figure.
the back panel taken apart.
Jan-16-2024 04:11 PM
I found a similar replacement motor which requires the connector to be removed and switched from old motor along with the shaft taken out of old motor and put in new one. if you pry the back of motor silver plug you can pull the shaft,, be careful to not loose the washer on shaft..
as for the plug wires , I just cut the new plug off, but the old plug off with spare wire spliced them together red to red etc. put some elec tape of heat shrink on if you have. mount new fan back in, blade back on shaft, put the back panel up make sure the blades are not jammed and tighten the two screws on top.. the replace fan motor on amazon is
Jan-03-2024 10:33 PM
Having the same issues, blink light on temp side,, and noticed the fan will run at times and not run at times. suspect it's either going bad or getting weak or something from the control module that there is 3 wires to it and have read it power, neg and feedback..
couple time when restarting noticed when compressor started the fan would "jump" and then not spin.. could take screwdrvier and spin blade to get started.. other times it starts and sping on it own.
did notice the other night the speed would go up and then down.. its rated at 2400 RPM so at full speed it moves a lot of air.. it ramps for 5 or so seconds then dies back to slower.. not sure what normal speed is as i have not sat and watched it like now..
Suspect when the fan is not running and compressor is it causes the compressor to get flooded
with refrigerant
and high head forcing a shut off and the blinking light is error light. ? trying to find the fan motor.. drf 292wepoo 04 02b with NO luck.. the shaft is 2.25 long.. on amazon they are 1.5 to 1.25
Oct-06-2023 08:08 AM
doughere wrote:
I'm just spit-balling, but I'd start with finding out why the fan in the freezer is not working. If its getting power, but not working; I'd suspect its not working could screw up the refrigeration system. If its not getting power, then it sounds like a control board problem.
I have absolutely no knowledge about this particular unit, this is just a thought on where to start looking !
Doug
Oct-05-2023 03:48 PM
