arcsum68
Jul 29, 2020Explorer
shastagary wrote:
if it actually worked good on the test bench then you may suspect the installation and proper parameters of the venting and how close it is mounted to the outside wall to get a proper cooling chimney effect.
is one of the vents on the cabin roof or are they both on the side wall?
the manual describes the parameters dometic rm 3600
Based on the PDF we are in clearance tolerance for height, also I have active fans blowing air up and out. I have also removed the top cover just to remove any restrictions, this obviously did not help.
Update, I believe it is a Dometic Americana RM2652 or RM2852. I checked those clearances as well and still believe we have plenty of room. Sorry for not knowing exactly what it is, if it were mine I would be well versed. Due to multiple issues I had not been on the thing in 2 years until last weekend and it sparked my desire to either figure it out or at least reclaim the space.
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
