Dometic Fridge not cooling
Guitarboss
I have a Dometic RM2652 that has recently stopped cooling on electric or gas. When switching the unit from 120v to gas, the igniter works but no gas to light. I can tap on the top of the black solenoid that sits on to of the brass gas valve - at this point gas passes thru and the pilot will light but after about 5 seconds there is a click and the gas stops. I tried another solenoid but still had the same problem. I can light the stove in the kitchen and it lights and runs fine, telling me there is sufficient propane.
Any input and/or suggestions would be greatly appreciated!
Thanks!
Steve
15 REPLIES 15
donn0128
Do you smell anything strange when you open the outside access panels?
If not, then quite,likey the control board is bad. Dinosaur boards are reasonable and better than dometic boards.
