โAug-06-2016 03:03 PM
โOct-03-2016 01:48 PM
โOct-03-2016 12:03 PM
โAug-16-2016 05:40 PM
โAug-16-2016 04:41 PM
โAug-12-2016 11:01 PM
โAug-12-2016 08:43 PM
Guitarboss wrote:What I am talking about is disconnecting the two leads on the 120v heater element from the board with the refer off(no power) plug those into a 120v extension cord. You will have to make some male connectors to plug into the female spade connectors on the heating element. By doing this you by pass all the electrical stuff that controls the heating element. If your refer gets down into the 30's overnight the cooling unit is good and the problem will be something less costly to fix.Gjac wrote:
Before you replace any more parts I would check the cooling unit first to see if it is good by discontenting the 120v heater from the board and connecting it directly to a 120v source and let it run overnight. If the refer cools down your unit is good and the problem is elsewhere. Let us know the results. Did you read the troubleshooting section that Old Biscuit posted?
Gjac, I double checked that there is 120v coming from the board to the heating element. Also, when disconnecting power to the board the burner lights immediately and will continue to burn. Would there be an advantage to connecting the heater directly to 120v?
Replacing the control board did correct the problem with the unit not lighting...but unfortunately its not cooling. We do have quite an issue with dirt dobbers and I'm wondering if there could be a blockage to the cooling unit.
I appreciate any input!
Thanks!
โAug-12-2016 06:27 PM
โAug-12-2016 03:03 PM
โAug-11-2016 07:19 AM
โAug-11-2016 05:04 AM
โAug-06-2016 08:51 PM
โAug-06-2016 08:07 PM
โAug-06-2016 03:43 PM
donn0128 wrote:
Do you smell anything strange when you open the outside access panels?
If not, then quite,likey the control board is bad. Dinosaur boards are reasonable and better than dometic boards.
โAug-06-2016 03:14 PM
