dougrainer
Jun 17, 2023Nomad
rvman69 wrote:
I got the old cooling unit out. Even though I got the plastic liner under the fins separated good it still ripped my liner on both sides some. I seen where once you get it back together you can put some RV caulking on it and it will be fine. Is this true? Also do I need to do anything where the double sided tape was on the fins? Thanks
You do not need to worry about the tape. IF you use the correct sealant when installing the new CU in the square hole, that will insulate for the cracked plastic. Yes, I would use a good silicone once installed on those cracks. Doug
