Marcela's avatar
Marcela
Dometic furnace no fire
Hello all. Have a brand new from the factory slide in truck camper and the furnace is failing me. Service centers look to be nonexistent for the Dometic brand in the midwest.
There is gas to the stove and water heater, they fire instantly.
I have cycled the furnace enough times the propane should be at the burner.
I can hear the spark ignite and the fan starts simultaneously and then the fan stops and nothing. It will do this 4-6 times then quit this process and the red light on the circuit board lights up continuously, which the instruction say is an internal circuit board failure.
So is the circuit board telling the truth and need to be replaced or is there some routine I am missing. I have tried the instructions in the manual and different processes of starting to no avail.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
