dougrainer
Aug 26, 2020Nomad
Since you have OHM reading on the 120 element, Wire the heat element DIRECT to 120 volt power, bypassing the rear control board. leave plugged in for 24 hours. Install a small glass of water in the lower refer section. AFTER 24 hours, if that water is NOT below 40 degrees, your Cooling Unit is BAD. Doug
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 25, 2025
