E-Wad's avatar
E-Wad
Dometic Refrigerator Leaks When Defrosting
Good Day All,
I have a Dometic RM2862 (2007 5th wheel) refrigerator. When I defrost the unit, I get water under the unit on the floor it sets on. When I first discovered this problem, it was from water on the stuff in the drawer under the refrigerator -- it soaked through the floor and dripped into the drawer.
IT'S NOT the drain hose or drain pan catch cup, because now when I defrost, I switch the drip pan (under the cooling fins) around so the drain hole is on the opposite front and catch the water in a plastic milk jug. There is no drainage via the drain system. Also, this occurs whether I defrost just the refrigerator or both including the freezer.
I now place a piece of cardboard under the unit to catch the water that drips from the underside of the refer, to avoid it soaking into the plywood floor. The most water comes from the right side behind the heat exchanger vent stack.
My only guess is that when the frost melts, it is somehow seeping through the rivets that hold on the cooling fins, migrating behind the back wall and down. That being said, the amount of water I get, it would have to be multiple leaks.
I am hoping for some in-sight from the forum.
Thank you in advance.
  • Never heard of water migrating through screws that hold fridge fins - water tend to go down and any sideways migration would likely be miniscule. Pretty sure water leaks are limited to ice maker and clogged defrost drip tube. Any chance you have an ice maker?
    BTW - You might be able to eliminate defrost issues by placing a fan on your fins - did that 20 years ago and haven't defrosted since.
  • Bill.Satellite wrote:
    How is the drain pan connected to the drain hose if you are able to turn the catch pan around. Maybe I don't quite understand what you are doing?!
    Thanks for taking time to reply.
    The drain catch basin and hose is a non issue. I am by-passing it and draining directly into a plastic jug. You can turn the catch pan around so the drain hole is in the front.
  • I would start by blowing compressed air through it. Or even remove the restrictor from the outside end and attach a clear plastic hose to the end and suck on it.
    Be sure to reinstall the restrictor in the end when you are finished.
    Once you have verified that the hose is clear, if you get water outside it, replace the hose-- likely cracked.
  • Sounds like your drain hose has a clog or a crimp in in. If you can, try running a long thin wire through the hose. Maybe a small bug or critter crawled up the tube and died, clogging the flow.
  • How is the drain pan connected to the drain hose if you are able to turn the catch pan around. Maybe I don't quite understand what you are doing?!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
