Chris_Bryant
Mar 06, 2016Explorer II
Because you talked about a locking mechanism, it sounds like you have an RM8500 series. If so, it just needs programming.
To access the service mode:
This from the service manual I have online at my service manual page- it also tells how to program the lock, but it's an odd manual, translated from German.
Controlling the interior light via reed switch
The AES-Electronics uses the X114 and X111 as well for controlling the reed
switch as well as the electrical lock.
The electronics will recognize the application of a reed switch, following the
below steps:
1. Choose step 9 in the service mode
2. Open the door
3. Close the door (reed switch will be recognized)
4. Continue service mode (push button 6)
The interior light will now be controlled via the reed switch.
Basically the electronics are defined with “recognizing Reed switch”.
Service Mode AES
The Service Mode is activated by keeping pressed down the temperature button
and switching on the main button.
After this the 7-Segment-Display shows „1“. By pushing the temperature button,
the different test-steps can be activated:
1 = activates 120 V heating element (120V must be available)
2 = activates 120V relay (120V has not to be necessarily available)
3 = activates 12 V heating element (D+ and 12V supply has to be available)
4 = Intern test step (is not indicated)
5 = activates burner control device – output (Gas operation)
6 = activates frame heating
7 = activates interior lights (Except for electrical lock)
8 = Intern test step (is not indicated)
9 = Recognizing electrical lock or reed switch
10 = activates all 7 segment-components one after the other
11 = activates all LED´s
Exiting the diagnosis mode: Push „mode“ button or wait for 10 minutes.
