MT_BOB
Oct 15, 2021Explorer
Wow,sounds more like it was not working at all, for that temp. rise. Are you sure it was even working? You can touch the "chimney", and it will get very hot, enough to burn you. A few other things--
Check the DC voltage, while the camper is plugged in to your house.Will leave a link with some tech info.
Then check the DC voltage when the camper is unplugged. They should be almost the same, the unit requires DC even on gas.
You also can perform the "running on gas" tests at home, with and without the camper being plugged in to your home.
Anyway, more stuff for you to consider, and here is the basic manual.
https://www.gas-refrigerators.com/pdf/RM2351-manual.pdf
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
