wa8yxm
Sep 13, 2023Explorer III
rk911 wrote:
and leaving the gray tank open is a bad idea for reasons other than the flies. and open gray tank valve allows gas from the dump connection to flow thru the hose and up thru the exhaust pipe on the roof. not good for the neighbors.
THANK YOU (Folks you look at the ads for the useless black tank odor control that show the stinky RV.. Gray valve left open Guarantee it)
How about this. a painter's pole with a window washer's squegee end nstead of a paint brush and a couple of zip ties to the handle of the valve. Crawl under to attach and to remove.. Or you can develop basic device to use as a push/pull tool very easily with one of those extension handles.. They are also the same size as your basic Plumber's friend handle. (Plunger)
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
