NinerBikes
Feb 26, 2014Explorer
rexlion wrote:
I tried measuring the circuit between my solar panel and the controller today, but couldn't get a reading. I was wondering, should a digital multimeter (I have a Fluke 115) be able to read small amounts of current like 2 or 3 amps? My panel should put out a max of 4A in bright sun, but I would like to see what the actual output is in a variety of conditions (bright haze, cloudy, etc).
Has anyone done this or have ideas on an easy way to do it? Will a clamp meter (TRMS) do the job?
I know the system is functioning, because I can measure the voltage inside the trailer (in a 12V socket) and it goes to 14.14V when the panel is hooked up.
Watt amp meter for solar panel.
