โJan-22-2017 09:00 AM
โJun-05-2017 09:36 AM
โJun-05-2017 09:21 AM
โFeb-01-2017 01:13 PM
pianotuna wrote:
CR,
Any idea what the line voltage is when running the heat pump? Perhaps the Sola is boosting from 100 volts?
โFeb-01-2017 12:13 PM
โFeb-01-2017 11:06 AM
time2roll wrote:
12,000 BTU makes 1 ton ice in 24 hours. You would appear to have 24,000 BTU
Heating vs cooling may have different BTU rating.
โFeb-01-2017 11:03 AM
Canadian Rainbirds wrote:
Also, the Sola Basic was very disappointing. I have taken it out of circuit. It bucks even when the incoming voltage is 125 and drops it to anywhere between 109 and 112 volts. When the compressor kicks in it is too slow to catch up with the voltage drop and the Inverter either inverts (165 amps from the batteries) or interrupts the power. Sometimes it starts the heatpump OK and then the voltage holds at 115 or so.
Even when line voltage is low it seldom boosts above 112VAC under minimum load though occasionally I have seen it at 117.
โFeb-01-2017 10:26 AM
โFeb-01-2017 10:04 AM
pianotuna wrote:
Hi,
How many btu's is the heat pump? My air conditioner is 13,500.
Can you wire around the prosine easily?
โJan-24-2017 06:17 PM
โJan-24-2017 06:16 PM
โJan-24-2017 05:46 PM
โJan-22-2017 10:47 AM
โJan-22-2017 09:10 AM
